Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 10
Paso 10
Remove the display assembly. For comprehensive instructions on how to reinstall the Pixel XL display, follow this guide. If your replacement display did not come with a speaker grille, use tweezers to gently peel the adhesive grille from your old display, and transfer it to the replacement.
  • Remove the display assembly.
  • For comprehensive instructions on how to reinstall the Pixel XL display, follow this guide.
  • If your replacement display did not come with a speaker grille, use tweezers to gently peel the adhesive grille from your old display, and transfer it to the replacement.
  • Before installing a new display, be sure to remove all traces of adhesive from the frame. Use a spudger or an opening tool to scrape it off, and use high-concentration isopropyl alcohol to remove any residue.
  • If you are reinstalling the same display assembly, be sure to remove all adhesive residue from the panel and the frame before applying new adhesive.
  • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
Insertar traducción aquí
