Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 6
Once you have sliced around the perimeter of the phone, carefully lift the display assembly up slightly by the right corners.
  • Once you have sliced around the perimeter of the phone, carefully lift the display assembly up slightly by the right corners.
  • Do not attempt to remove the display assembly. It is still attached by a flex cable.
  • Use an opening pick to slice through any remaining adhesive.
Insertar traducción aquí
