Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 5
Lift up the main flex cable covering the loudspeaker assembly with a Spudger Take care to not damage the loudspeaker. The flex cable is attached to the assembly with adhesive and is a little bit sticky. Lift up the whole loudspeaker assembly with a spudger and remove it.
  • Lift up the main flex cable covering the loudspeaker assembly with a Spudger
  • Take care to not damage the loudspeaker. The flex cable is attached to the assembly with adhesive and is a little bit sticky.
  • Lift up the whole loudspeaker assembly with a spudger and remove it.
Insertar traducción aquí
