Saltar al contenido principal
Inglés
Español
Paso 2
Use an iOpener to loosen the adhesive underneath the display of your phone. The stickiest areas are in the upper and lower area of your display. After cooling down, the adhesive will stick to the mid frame again. If needed reheat it.
  • Use an iOpener to loosen the adhesive underneath the display of your phone.
  • The stickiest areas are in the upper and lower area of your display. After cooling down, the adhesive will stick to the mid frame again. If needed reheat it.
  • After the adhesive at the lower end of your phone is loosened, pull up the display with your suction handle and insert an opening pick.
Insertar traducción aquí
