Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 6
Flip the phone over. Push an opening pick slowly and firmly down the right edge of the battery (which should be warm). Slide it slightly back and forth to slice through the adhesive. Be careful not to snag the white antenna cable running along the edge of the battery while you are push down on the pick.
  • Flip the phone over.
  • Push an opening pick slowly and firmly down the right edge of the battery (which should be warm). Slide it slightly back and forth to slice through the adhesive.
  • Be careful not to snag the white antenna cable running along the edge of the battery while you are push down on the pick.
  • If you are having a hard time getting the opening pick under the battery, heat and re-apply an iOpener as instructed in the previous step.
  • You can also apply some high concentration isopropyl alcohol to the edge in order to help weaken the adhesive.
  • Once you have loosened the right side of the battery from the case, leave an opening pick in place to prevent the adhesive from re-adhering.
Desconecta la batería utilizando un spudger para levantar el conector de batería.
Un cable grande de interconexión de placa hija cubre la batería. Antes de remover la batería, necesitarás separar este cable y sacar lo fuera del camino.
Despega la cinta que cubre el extremo inferior del cable para revelar dónde se conecta a la placa hija. Luego, usa tu spudger para levantar el cable y desconectarlo.
Si deseas, puedes hacer lo mismo en el extremo superior del cable para separarlo y removerlo completamente o podrías simplemente doblar el cable cuidadosamente para sacarlo del camino mientras remueves la batería.
[* red] Disconnectblack] Flip the battery by using a spudger to pry up the battery connectorphone over.
[* icon_note] A large daughterboard interconnect cable coversblack] Push an opening pick slowly and firmly down the battery. Before removingright edge of the battery, you will needbattery (which should be warm). Slide it slightly back and forth to detach thisslice through the adhesive.
[* icon_caution] Be careful not to snag the white antenna
cable and move it outrunning along the edge of the way.
[* orange] Peel back
battery while you are push down on the tape coveringpick.
[* icon_note] If you are having a hard time getting
the lower end ofopening pick under the cable to reveal where it connectsbattery, heat and re-apply an iOpener as instructed in the previous step.
[* icon_note] You can also apply some high concentration isopropyl alcohol
to the daughterboard. Then, use your spudgeredge in order to pry uphelp weaken the cable and disconnect itadhesive.
[* black] If desired,Once you can dohave loosened the same at the top endright side of the cablebattery from the case, leave an opening pick in place to detach and remove it completely, or you may simply bend the cable gently out of the way while you removeprevent the batteryadhesive from re-adhering.
