Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
The battery is secured by two strips of double-sided tape. Heat an iOpener and place it on the back of the phone's left edge for two minutes. You may need to reheat and reapply the iOpener.
  • The battery is secured by two strips of double-sided tape.
  • Heat an iOpener and place it on the back of the phone's left edge for two minutes. You may need to reheat and reapply the iOpener.
Remueve los siete tornillos T5 negros de 4mm.
Remueve los dos tornillos T5 plateados de 3mm los cuales aseguran el ensamble del marco central.
Habrán clics a medida que levantes del teléfono el marco central debido a los clips que normalmente lo mantienen en su lugar.
Levanta el marco central de la carcasa trasera halándolo hacia arriba.
[* red] Remove the seven black 4mm T5 screws.
[* orange] Remove the
The battery is secured by two silver 3mm T5 screws which secure the mid frame assemblystrips of double-sided tape.
[* icon_note] There will be clicks as you takeblack] [guide|25705|Heat an iOpener|new_window=true] and place it on the mid frame out'''back of the phone duephone's left edge''' for two minutes. You may need to reheat and reapply the clips that normally hold it in place.
[* black] Lift the mid frame from the rear casing by pulling it upwards
iOpener.
iOpener.
