Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard. To reconnect during reinstallation, align the cable with the socket and use your finger to press down on one side, followed by the other. If done correctly, the cable should be firmly held in place by the socket.
  • Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard.
  • To reconnect during reinstallation, align the cable with the socket and use your finger to press down on one side, followed by the other. If done correctly, the cable should be firmly held in place by the socket.
Usa un destornillador T5 para remover los dos tornillos negros de 4mm que mantienen el escudo del conector de la pantalla en su lugar.
Remueve gentilmente el escudo de metal del conector de la pantalla.
[* redblack] Use the T5 screwdriverpoint of a spudger to removepry up and disconnect the two black 4mm screws which holdinterconnect cable from the screen connector shield in placemotherboard.
[* black] Gently removeicon_reminder] To reconnect during reinstallation, align the cable with the socket and use your finger to press down on one side, followed by the other. If done correctly, the cable should be firmly held in place by the metal screen connector shieldsocket.
