Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 5
There is a bracket crimped onto the antenna cable that is adhered to the speaker enclosure. The adhesive must be severed in order to extract the antenna. Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket. Slide the pick to the right to cut the adhesive.
  • There is a bracket crimped onto the antenna cable that is adhered to the speaker enclosure. The adhesive must be severed in order to extract the antenna.
  • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
  • Slide the pick to the right to cut the adhesive.
  • Push the bracket away from the speaker to clear it of the tape under it.
Insertar traducción aquí
