Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 71 guías que incluyan este paso.
Inglés
Español
Paso 18
Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go. The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad. The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
  • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
  • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
Inserta una púa de apertura y deslízala hacia el centro del borde derecho del iPad, liberando el adhesivo a medida que avanza.
Los cables de la pantalla se encuentran aproximadamente a la mitad de la parte inferior del iPad. Deja de deslizar la púa cuando obtenga ~ 4.5" desde la parte inferior del iPad.
