Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 21 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Make sure the battery is disconnected before you disconnect or reconnect the cables in this step. Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board. To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
  • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
  • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
Asegúrate de que la batería esté desconectada antes de desconectar o reconectar los cables en este paso.
Utiliza la parte plana de un spudger o tu uña para desconectar los dos conectores inferiores de la pantalla haciendo palanca hacia arriba de sus puertos de conexión en la placa lógica.
Para reconectar estos cables, presiona un extremo hasta que encaje en su lugar, luego repite en el extremo opuesto. No presiones en el medio. Si el conector está ligeramente mal alineado, el conector se puede doblar y causar daño permanente.
Si tienes un pantalla en blanco, líneas blancas en la pantalla, o no tienes respuesta táctil completa o parcial después de volver a ensamblar tu teléfono, intenta desconectar y reconectar con cuidado ambos cables y asegúrate de que estén encajados completamente.
