Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
Remove the optical drive
  • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
Quita el tornillo que sujeta la unidad óptica. Para hacer esto, usa un destornillador Phillips # 0. Desliza la unidad óptica hacia afuera una vez que se quita el tornillo
