Saltar al contenido principal
Inglés
Español
Paso 4
The battery isn't immediately disconnectable; the midframe components must first be removed.
  • The battery isn't immediately disconnectable; the midframe components must first be removed.
  • Several identical Phillips #00 screws secure the midframe/antenna assembly. These are the only screws in the device.
  • The lower speaker/antenna portion must be removed first; the upper portion comes out second, and has the NFC coil adhered to it.
La batería no se desconecta de inmediato; Los componentes del marco medio deben removerse primero.
Varios tornillos Phillips # 00 idénticos aseguran el ensamblaje de antena/marco medio. Estos son los únicos tornillos en el dispositivo.
La parte inferior del altavoz/antena debe retirarse primero. La parte superior sale en segundo lugar, y tiene la bobina NFC adherida a ella.
