Saltar al contenido principal
Inglés
Español
Paso 13
Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side. If it is difficult to pry out the connector completely with the spudger, you may remove it by hand. If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
  • Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side.
  • If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
Insertar traducción aquí
