Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
While depressing the connector lock, use a heavy duty spudger to pry the power supply connector away from its socket on the logic board. It will be necessary to work from alternate sides until the connector is free. Your power supply may have an ambient light sensor cable attached from the power supply to the logic board. If so, carefully use a spudger to push out the cable towards you using the sides of the cable alternatively to help you slide it out.
  • While depressing the connector lock, use a heavy duty spudger to pry the power supply connector away from its socket on the logic board.
  • It will be necessary to work from alternate sides until the connector is free.
  • Your power supply may have an ambient light sensor cable attached from the power supply to the logic board. If so, carefully use a spudger to push out the cable towards you using the sides of the cable alternatively to help you slide it out.
Insertar traducción aquí
