Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 7
Let's hope that Samsung's improved testing procedures are what the Note7 was missing, because this design looks about the same to us. And it's still a bear to pry it off that adhesive. Even with the battery fully removed, the glue won't let go. The S8+ features a 13.48 Wh (3500 mAh at 3.85 V) battery—the exact same capacity as the Note7, and a little less than the S7 Edge's 13.86 Wh.
  • Let's hope that Samsung's improved testing procedures are what the Note7 was missing, because this design looks about the same to us.
  • And it's still a bear to pry it off that adhesive. Even with the battery fully removed, the glue won't let go.
  • The S8+ features a 13.48 Wh (3500 mAh at 3.85 V) battery—the exact same capacity as the Note7, and a little less than the S7 Edge's 13.86 Wh.
  • Samsung continues to beat Apple in the battery capacity wars, with the iPhone 7+ weighing in at 11.1 Wh (2900 mAh at 3.82 V).
  • However, the iPhone may make better use of its smaller battery, outlasting the S8+ in use testing.
Esperemos que los procedimientos de evaluación mejorados de Samsung sean lo que le faltaba al Note7, porque este diseño se ve igual para nosotros.
Y sacar ese adhesivo sigue siendo dificultoso, aun cuando la batería está completamente removida, el pegamento no sale.
El S8+ tiene una batería de 13.48 Wh (3500 mAh a 3.85 V)—exactamente la misma capacidad que el Note7 y un poco menos que el S7 Edge con 13.86 Wh.
Samsung continúa ganándole a Apple en la guerra de capacidad de baterías, con el iPhone 7+ de 11.1 Wh (2900 mAh a 3.82 V).
Sin embargo, el iPhone podría utilizar de mejor forma su batería más pequeña, durando más que la del S8+ en pruebas de uso.
