Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Insert the flat end of a spudger into the gap between the SATA data connector and the hard drive. Twist the spudger to separate the SATA data connector from the hard drive, then disconnect it from the hard drive.
  • Insert the flat end of a spudger into the gap between the SATA data connector and the hard drive.
  • Twist the spudger to separate the SATA data connector from the hard drive, then disconnect it from the hard drive.
  • Repeat this process for the SATA power connector.
Insertar traducción aquí
