Saltar al contenido principal
Inglés
Español
Paso 2
These antenna cables may need to be replaced should the connection drop from the XM Satellite service. To remove, catch the side of the connector with a fingernail moving upward until the connectors pops up from the board. After the U.FL connector is loose, center the new connector cable over the mating U.FL connector and press down firmly.
  • These antenna cables may need to be replaced should the connection drop from the XM Satellite service.
  • To remove, catch the side of the connector with a fingernail moving upward until the connectors pops up from the board.
  • After the U.FL connector is loose, center the new connector cable over the mating U.FL connector and press down firmly.
  • CAUTION: The connectors are delicate, so take much care when reconnecting.
Insertar traducción aquí
