Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 10
At this point you can easy remove the fans Note: the one with the shorter cable and  4 wires is the center one (for the GPU core) the one with double 4 wire connector is the nearest to the gpu outputs
Fans remove
  • At this point you can easy remove the fans
  • Note: the one with the shorter cable and 4 wires is the center one (for the GPU core)
  • the one with double 4 wire connector is the nearest to the gpu outputs
Insertar traducción aquí
