Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 7
After the plastic cover is removed, locate the white, ribbon connector highlighted by the red square. Rotate the device 90 degrees counterclockwise to remove the ribbon connector.
  • After the plastic cover is removed, locate the white, ribbon connector highlighted by the red square.
  • Rotate the device 90 degrees counterclockwise to remove the ribbon connector.
Insertar traducción aquí
