Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection. Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard. During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
  • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
  • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
Insertar traducción aquí
