Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off. Use the tweezers to lift the faceplate  from the rest of the device. The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
  • Use the tweezers to lift the faceplate from the rest of the device.
  • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
Insertar traducción aquí
