Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place. For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
  • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Suavemente tira hacia atrás los border de la carcasa girando a lo largo de la bisagra al otro lado de la costura de apertura, como se muestra en la segunda foto. Las pestañas de plástico mantienen la cubierta en su sitio.
-[* black] Gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
+[* black] For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
+[* black] For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
