Saltar al contenido principal
Inglés
Español
Paso 2
Under the zipper panel are eight more 9.75mm Phillips head screws. Unscrew them and carefully lift the battery cover. Be careful not to damage the small white ribbon cable which connects the battery cover to the rest of the device.
  • Under the zipper panel are eight more 9.75mm Phillips head screws. Unscrew them and carefully lift the battery cover.
  • Be careful not to damage the small white ribbon cable which connects the battery cover to the rest of the device.
  • 2 small screws hold this part to the cover. For ease of future handling, remove them and gently pull this part out to release the cover.
Bajo el panel con cremallera, podrás ver ocho tornillos más, con cabeza Phillips de 9.75 mm. Desatorníllalos y levanta con cuidado la cobertura de la batería.
Ten cuidado de no dañar el pequeño cable plano de color blanco, que conecta esta cobertura con el resto del dispositivo.
