Saltar al contenido principal
Inglés
Español
Traduciendo paso 4
Paso 4
Carefully lift the battery free of the device, threading the cable through the hole in the case as you do so. Carefully lift the battery free of the device, threading the cable through the hole in the case as you do so. Carefully lift the battery free of the device, threading the cable through the hole in the case as you do so.
  • Carefully lift the battery free of the device, threading the cable through the hole in the case as you do so.
Levanta con cuidado la batería del dispositivo, y pasa el cable por el agujero de la carcasa mientras lo haces.
