Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Locate the three 9.7mm Phillips head screws inside the zipper compartment and unscrew them. Lift the zipper panel out of the speaker. The side of the panel opposite the screws is held in place by small clamps. The panel should easily lift free from the device, but may require gentle prying.
  • Locate the three 9.7mm Phillips head screws inside the zipper compartment and unscrew them.
  • Lift the zipper panel out of the speaker.
  • The side of the panel opposite the screws is held in place by small clamps. The panel should easily lift free from the device, but may require gentle prying.
Localiza los tres tornillos de cabeza Phillips de 9.7 mm en el interior del compartimento protegido con cremallera, y desatorníllalos.
Separa el panel con la cremallera del altavoz.
El lado del panel opuesto al de los tornillos se mantiene sujeto gracias a unas pequeños agarres. Este panel debería separarse fácilmente de esas pinzas en el altavoz, pero puede que necesites hacer algo de palanca.
