Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab. Pull the audio out ribbon cable off the adhesive securing it to the upper case. Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
  • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
  • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
  • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
Insertar traducción aquí
