Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Position the camera so the bottom is facing up and the display away from the surface. Gently pry the screen portion from the camera portion with your fingers or a plastic prybar. Do not fully separate the two components! the screen is attached by two ribbon cables.
  • Position the camera so the bottom is facing up and the display away from the surface.
  • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
  • Do not fully separate the two components! the screen is attached by two ribbon cables.
  • Lay the display flat to expose the circuit board and the display control ribbon cables.
Insertar traducción aquí
