Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Now turn your attention to the camera sensor and battery housing. Identify the two connection points of the large ribbon cable. Carefully place a flathead screwdriver under the left ribbon cable connection point and pull up to disconnect. Repeat the previous step but this time carefully remove the right ribbon cable connection point.
  • Now turn your attention to the camera sensor and battery housing. Identify the two connection points of the large ribbon cable.
  • Carefully place a flathead screwdriver under the left ribbon cable connection point and pull up to disconnect.
  • Repeat the previous step but this time carefully remove the right ribbon cable connection point.
  • After both sides of the ribbon cable have been disconnected it is ready to be replaced.
Insertar traducción aquí
