Saltar al contenido principal
Inglés
Español
Paso 2
Unscrew ten screws using a Phillips #000 screwdriver. Push screwdriver into screw and then turn, keeping firm pressure on the screwdriver, to avoid stripping the screw. After unscrewing a screw, place it next to the hole it was taken from. When it is time to replace the screws this will avoid any confusion, as there are several longer screws.
Remove Screws
  • Unscrew ten screws using a Phillips #000 screwdriver. Push screwdriver into screw and then turn, keeping firm pressure on the screwdriver, to avoid stripping the screw.
  • After unscrewing a screw, place it next to the hole it was taken from. When it is time to replace the screws this will avoid any confusion, as there are several longer screws.
Desatornilla diez tornillos con un destornillador Phillips # 000. Empuja el destornillador en el tornillo y luego gíralo, manteniendo una presión firme sobre el destornillador, para evitar dañar el tornillo.
Después de desatornillar un tornillo, colócalo junto al orificio del que se extrajo. Cuando llegue el momento de reemplazar los tornillos, esto evitará cualquier confusión, ya que hay varios tornillos más largos.
