Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 28 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable. Align the cable's SATA connector with the drive's port and plug in securely. Plug the USB connector into your laptop and your optical drive is ready for use.
  • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
  • Align the cable's SATA connector with the drive's port and plug in securely.
  • Plug the USB connector into your laptop and your optical drive is ready for use.
¡No tires el lector! Puedes usarlo de manera externa con nuestro cable SATA USB lector óptico.
Alinea el conector SATA del cable con el puerto del lector y conéctalo cuidadosamente.
Conecta el conector USB a tu portátil. Tu lector óptico está listo.
