Saltar al contenido principal
Inglés
Español
Paso 3
To the bottom right is a screw that connects a ground strap and holds the board to the chassis, undo that. With all the connector disconnected, the ground strap removed, pull the DM board carefully from the chassis. Some models have a small tab stop that you must push down to release the board. With all the connector disconnected, the ground strap removed, pull the DM board carefully from the chassis. Some models have a small tab stop that you must push down to release the board.
  • To the bottom right is a screw that connects a ground strap and holds the board to the chassis, undo that.
  • With all the connector disconnected, the ground strap removed, pull the DM board carefully from the chassis. Some models have a small tab stop that you must push down to release the board.
Insertar traducción aquí
