Saltar al contenido principal
Inglés
Holandés
Paso 4
Before installing new brake pads, you will need to compress the brake caliper pistons (shown in red) so that the pads fit inside the caliper. Use a chisel or pry bar to gently push the pistons away from the brake rotor and back into the caliper. Use a chisel or pry bar to gently push the pistons away from the brake rotor and back into the caliper.
  • Before installing new brake pads, you will need to compress the brake caliper pistons (shown in red) so that the pads fit inside the caliper.
  • Use a chisel or pry bar to gently push the pistons away from the brake rotor and back into the caliper.
Insertar traducción aquí
