Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a plastic opening tool or your fingernail to lift up the tab on the front-facing camera ribbon cable ZIF connector. Make sure you're prying on the tab and not the connector itself. Lift the front-facing camera out of the antenna with the plastic opening tool and remove it.
  • Use a plastic opening tool or your fingernail to lift up the tab on the front-facing camera ribbon cable ZIF connector.
  • Make sure you're prying on the tab and not the connector itself.
  • Lift the front-facing camera out of the antenna with the plastic opening tool and remove it.
Insertar traducción aquí
