Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Remove the two 3.3 mm T5 Torx battery terminal screws. Grab the blue battery removal tab and lift the battery out to remove it. There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
  • Remove the two 3.3 mm T5 Torx battery terminal screws.
  • Grab the blue battery removal tab and lift the battery out to remove it.
  • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
  • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
Insertar traducción aquí
