Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Pull the back cover away from the phone to remove it. The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces. The battery must remain in the phone and not come off with the back cover or you will break the power lead.
  • Pull the back cover away from the phone to remove it.
  • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
  • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
  • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
Insertar traducción aquí
