Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Use a plastic opening tool or your fingernail  to lift up the tab on the rear-facing camera ribbon cable ZIF connector. Make sure you're prying on the tab and not the connector itself. Push the rear-facing camera through its hole in the grey antenna and remove it.
  • Use a plastic opening tool or your fingernail to lift up the tab on the rear-facing camera ribbon cable ZIF connector.
    • Make sure you're prying on the tab and not the connector itself.
  • Push the rear-facing camera through its hole in the grey antenna and remove it.
Insertar traducción aquí
