Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 10
The display bezel can be a first-out component, not requiring the above disassembly. The bezel is secured with plastic clips, prying is relatively simple, but care must be taken to avoid scratching the unprotected display. The LCD is secured with four screws and has a single display data interconnect cable plugged into the back.
  • The display bezel can be a first-out component, not requiring the above disassembly.
  • The bezel is secured with plastic clips, prying is relatively simple, but care must be taken to avoid scratching the unprotected display.
  • The LCD is secured with four screws and has a single display data interconnect cable plugged into the back.
  • Displays are high priority components in laptops as they are fragile and easily broken. A display that is accessible with minimal disassembly, and which has no peripheral components built in means a quick, inexpensive repair.
Insertar traducción aquí
