Saltar al contenido principal
Inglés
Español
Paso 6
SIM card tray was easily removed with a fingernail. The motherboard is secured by light adhesive and was easy to pry up. The display and button cables are connected to the underside of the motherboard. However, the cables are long enough that you can tilt the board and disconnect the ZIF connectors without much chance of damage.
  • SIM card tray was easily removed with a fingernail.
  • The motherboard is secured by light adhesive and was easy to pry up.
  • The display and button cables are connected to the underside of the motherboard. However, the cables are long enough that you can tilt the board and disconnect the ZIF connectors without much chance of damage.
  • With the motherboard out of the way, we could remove the loudspeaker, headphone jack, USB-C port, button cable, interior and exterior button covers, and fingerprint sensor.
  • Modular components, especially high-wear ones like headphone jack and charging port are excellent for repair.
Insertar traducción aquí
