Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 7
The only remaining removable component is the earpiece speaker.
  • The only remaining removable component is the earpiece speaker.
  • Display assemblies like this (fused display and midframe assembly) make for pricy replacement parts. This component is also the last out, while it's the most in danger of failing from simple falls etc.
  • While it is possible to replace just the LCD and digitiser It may be more trouble than it's worth
  • To remove the old screen from the assembly heat (freezing might work better, but I have not tried) the screen and press on the screen through this hole, then It's just a matter of lots of heat and scraping.
  • removing the old LCD/digitiser from the assembly with almost certainly destroy it.
  • Removing the LCD/digitiser without scattering broken glass everywhere may not be possible
  • it takes a LOT of heat to remove the LCD/digitiser, you may melt the screen for the earpiece speaker if you are not careful (or even if you are)
Insertar traducción aquí
