Saltar al contenido principal
Inglés
Español
Paso 2
Super stiff clips around the perimeter of the "bathtub" rear case, hardcore prying required to remove the rear case. Seam is super thin and tough to get tools into. Fingerprint sensor cable connects rear case to rest of the phone, makes a little trap when you're opening it up. Not enough slack to lay the rear case on its side to continue working on the phone, sensor cable must be disconnected.
  • Super stiff clips around the perimeter of the "bathtub" rear case, hardcore prying required to remove the rear case. Seam is super thin and tough to get tools into.
  • Fingerprint sensor cable connects rear case to rest of the phone, makes a little trap when you're opening it up.
  • Not enough slack to lay the rear case on its side to continue working on the phone, sensor cable must be disconnected.
  • Fingerprint sensor itself is pretty easy to push out of the rear case. Has a standard press-on connector.
  • Side button covers can also be removed at this point.
Insertar traducción aquí
