Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 6
The rear-facing camera is secured in place by the motherboard. It is easy to remove after the motherboard is removed. The earpiece speaker is held in place by light adhesive and can be removed by prying.
  • The rear-facing camera is secured in place by the motherboard. It is easy to remove after the motherboard is removed.
  • The earpiece speaker is held in place by light adhesive and can be removed by prying.
  • The vibration motor is held in place by light adhesive and can be removed by prying.
La cámara posterior está asegurada en su lugar por la placa base. Es fácil de quitar después de que se retira la placa madre.
El altavoz del auricular se mantiene en su lugar con un adhesivo ligero y se puede quitar haciendo palanca.
El motor de vibración se mantiene en su lugar con un adhesivo ligero y se puede quitar haciendo palanca.
