Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use two blue plastic opening tools to remove the three wire connectors on the side of the input/output board. Use a Philips #0 screwdriver to remove the five screws on the board. One of the screws is hidden below the black tape, so gently pull the tape to the side to gain access to it. Be sure to replace the tape when reinstalling the board.
  • Use two blue plastic opening tools to remove the three wire connectors on the side of the input/output board.
  • Use a Philips #0 screwdriver to remove the five screws on the board.
  • One of the screws is hidden below the black tape, so gently pull the tape to the side to gain access to it. Be sure to replace the tape when reinstalling the board.
  • Lift board from case.
Insertar traducción aquí
