Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 3
Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges. Gently lift up the entire top plastic section of the speaker.  Do so slowly, the section is still connected to the circuitboard by a belt.
  • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
  • Gently lift up the entire top plastic section of the speaker. Do so slowly, the section is still connected to the circuitboard by a belt.
  • Gently remove the belt from its junction on the board, and after doing so the top plastic casing of the speaker will be fully detached.
Insertar traducción aquí
