Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 19
The controllers shed their skin for a close-up comparison. We bring you, Red vs. Blue. We aren't shallow—it's what's inside that counts. The red Joy-Con comes out ahead with IR hardware and an NFC antenna. The IR hardware consists of an IR camera and four IR LEDs. Nintendo says that the camera can detect different hand shapes, distance, and in the future will be able to record video. As for the LEDs, our bet is that they  cast IR light onto nearby objects to make them easier to identify.
  • The controllers shed their skin for a close-up comparison. We bring you, Red vs. Blue.
  • We aren't shallow—it's what's inside that counts. The red Joy-Con comes out ahead with IR hardware and an NFC antenna.
  • The IR hardware consists of an IR camera and four IR LEDs. Nintendo says that the camera can detect different hand shapes, distance, and in the future will be able to record video. As for the LEDs, our bet is that they cast IR light onto nearby objects to make them easier to identify.
  • You know what both have though? Two Phillips screws holding the joystick and two Phillips screws holding the board. That's what.
  • Blue, you are there for us repair folk when it counts.
  • On the bottom of each rests a hefty HD Rumble motor weighing in at 5.5 grams.
Los controladores arrojan su piel para una comparación de primer plano. Te traemos, rojo vs. azul.
No somos superficiales: lo que hay dentro es lo que cuenta. El Joy-Con rojo sale con hardware IR y una antena NFC.
El hardware IR consta de una cámara IR y cuatro LEDs IR. Nintendo dice que la cámara puede detectar diferentes formas de manos, distancia y en el futuro podrá grabar videos. En cuanto a los LED, nuestra apuesta es que proyectan luz IR sobre objetos cercanos para que sean más fáciles de identificar.
¿Sabes lo que ambos tienen? Dos tornillos Phillips sujetando el joystick y dos tornillos Phillips sujetando el tablero. Eso es lo que tienen.
Azul, estás ahí para nosotros los reparadores, cuando sea necesario.
En la parte inferior de cada uno existe un fuerte motor HD Rumble que pesa 5.5 gramos.
