Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 14
Unlike a lot of modern touchscreen devices, the digitizer on the Switch is not fused to the display, meaning you can replace the two parts independently. Thanks for keeping repairability in mind Nintendo! The digitizer is adhered by a double-sided adhesive strip that runs around the perimeter of the display. With a bit of heating and prying, we manage to coax the digitizer off. But in all our excitement, our hasty teardowner severed the digitizer data cable. Fixers be warned, this book opens longways.
  • Unlike a lot of modern touchscreen devices, the digitizer on the Switch is not fused to the display, meaning you can replace the two parts independently. Thanks for keeping repairability in mind Nintendo!
  • The digitizer is adhered by a double-sided adhesive strip that runs around the perimeter of the display. With a bit of heating and prying, we manage to coax the digitizer off.
  • But in all our excitement, our hasty teardowner severed the digitizer data cable. Fixers be warned, this book opens longways.
A diferencia de muchos dispositivos modernos con pantalla táctil, el digitalizador en el Switch no está unido a la pantalla, lo que significa que puedes reemplazar las dos partes de forma independiente. ¡Gracias por tener en cuenta la reparabilidad, Nintendo!
El digitalizador está adherido por una tira adhesiva de doble cara que se extiende alrededor del perímetro de la pantalla. Con un poco de calentamiento y palanca, logramos separar el digitalizador.
Pero con toda nuestra emoción, nuestro veloz desmontaje cortó el cable de datos del digitalizador. Se advierte a los reparadores, este libro se abre a lo largo.
