Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Traduciendo paso 2
Paso 2
Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
[* icon_caution] Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen. [* black] Use an iSclack or a suction handle to separate the [* icon_note] In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel. |
[* icon_caution] Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit. |
