Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Paso 2
Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen. Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
  • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
  • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
  • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
  • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
Usa un ISclack o un mango de ventosa para separar la unidad de pantalla del panel trasero.
No remuevas el panel trasero completamente aun. Hay un cable conectado al panel. Va desde el sensor de huella digital hasta la unidad de pantalla.
-[* black] Use an iSclack or a suction handle to separate the display unit from the rear panel.
+[* icon_caution] Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
+[* black] Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
+ [* icon_note] In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
[* icon_caution] Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
