Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Using the plastic opening tools, gently pry the speaker from the headphone's base.
  • Using the plastic opening tools, gently pry the speaker from the headphone's base.
  • There will be some tearing involved, but this is necessary to remove the original cushion.
  • The cushion is bonded to the headphones with a circular adhesive strip. If you plan on reusing the cushion, try to keep the adhesive attached to the cushion during removal. This way the cushion can be easily re-attached to the headphones after repair.
Insertar traducción aquí
