Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
Unscrew the two Phillips #00 screws that hold the metal plate in place. The plate, which is covering the battery connector, has two little hooks on each side. Use a tweezer to free them and unhinge the plate by carefully moving it upwards. The plate, which is covering the battery connector, has two little hooks on each side. Use a tweezer to free them and unhinge the plate by carefully moving it upwards.
  • Unscrew the two Phillips #00 screws that hold the metal plate in place.
  • The plate, which is covering the battery connector, has two little hooks on each side. Use a tweezer to free them and unhinge the plate by carefully moving it upwards.
Destornilla los dos tornillos Phillips #00 que sujetan la placa de metal en su lugar.
La placa que cubre el conector de batería tiene dos pequeños ganchos en cada lado. Usa una pinza para liberarlos y desengancharlos con cuidado moviéndolos hacia arriba.
