Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Using a Phillips #00 screw driver bit, remove the 11 screws holding the plastic covers, loudspeaker, and NFC antenna on. Using a guitar pick to break some light adhesive, remove the top two plastic plates, and the NFC antenna. NOTE: If the adhesive is too strong, try applying more heat.
Remove the plastic covers
  • Using a Phillips #00 screw driver bit, remove the 11 screws holding the plastic covers, loudspeaker, and NFC antenna on.
  • Using a guitar pick to break some light adhesive, remove the top two plastic plates, and the NFC antenna.
  • NOTE: If the adhesive is too strong, try applying more heat.
  • Remove the loudspeaker assembly. You may have to peel up a small piece of gold/copper tape holding the assembly to the battery.
Insertar traducción aquí
